1 - 3 of 3 Posts
· Registered
Wow, there has been like 11 people look at this post and couldn't help? Anyways, its on the bottom of the carb straight up towards the gas tank from where the main jet goes in. It is just a little brass screw, you will need to tilt the carb sideways or use an offset screwdrive to turn it most likely. You may have to tilt the carb just to see it.
1 - 3 of 3 Posts
