Originally posted by sandman17@Jul 13 2004, 11:13 PM
I just bought a dyno-jet kit. There is a plug that is meant to block the air jet (term used in directions). What does it do? Why block it?
Here is wha I got from dynojet and also to make sure I understood myslef.
in a nut sheel is helph get more fuel flow into the system. The hole liks directly to the emultion tube and air needle.
But in a nut shell it helps remove air holes in the fule mix and draws more fuel. If you ant more infor call the 1-8XX number for dynojet, they are very helpful
Regards,
Fly
