If you have these i have a fix for the rattle and the slop. When I first got these I liked them, then they got loose and vibrated and got really loud. Well take the same size pipe that the "peg" rests on and weld the two pipes together. Then drill two holes one at each end of the pipe down through the foot peg and install two bolts and you just made these nerfs a lot more sturdier. As for the front where they meet you can install some o rings then a little bit of electrical or duct tape whatever you want, and no more vibration. I hope this helps if you have the same problems I had.
