1 - 3 of 3 Posts
checking availibilty of 100mm pistons and 94 mm stroker pistons.
need a high comp 94mm stroker piston this winter.a
heard you can stroke 4.2mm and use a crf piston. Or that there is stroker pistons available for this stroke. whats the word on larger than 3mm strokes? Looking to up the anti from a 501.
This is all on 05 machines.
3mm stroke on a 100mm bore with the venom piston puts ya right at 532.5, pretty sure kam has the pistons in stock, he has mine there,but i think there the crf style not sure of they work with the hotrods strokers,
Basically you need spacer plates or taller cylinders for more storke (at least I should say I do not have pistons with more pin offset).
I have 97 and 100m 3mil stroker pistons in stock (05 cranks)
Thanks
Kam
1 - 3 of 3 Posts
