1 - 12 of 12 Posts
I’m going to be getting my head ported and I’m wondering what the 5 angle or 3 angle valve job does, does it give me extra power, and is it worth it for $192
192 is probably for the whole cutting, the standard 3 angle should go around 120-140$, so it's more like 50-70$.
I do it all the time on my heads, while I have no number and I doubt that someone have done back to back dyno pulls from a 3 to 5 angle valve job, it helps the flow around the seats on low lift and make the cam appear a tad bigger.
It helps air come out of the ports by giving the air more of a rounded surface to follow out of the head around the valve. Sharp edges or squarer angles are harder for the air to follow.
Who is doing the work and what is your goal would be questions to me. If it isn't a reputable shop who knows what they are doing neither is worth while. If you are just wanting a good pickup the 3 angle will probably be enough for you, if you are wanting every last .1 of hp then you need to ask if the 5 angle is worth the extra.
Discussion Starter #4
Ct racing, it’s $350 for porting and an extra $192 for a 5 angle valve job, I want extra power but I’m not sure if the 5 angle will give me any more, and is it worth 190, and if it does give me more power is it enough where I will notice and be happy with spending the extra money, thx
Did you ask Allen?
I would bet he can give you some I site on "his" valve jobs
Plus you don't seem to care what the members from this site say anyway, you asked where to send your head in another topic and never replied to the people that answered. There are reasons the responses you got didn't include CT. The other shops make more power then ct and have a more proven track record.
One quote I remember from member dirteater when he did the first pull at ct on the dyno was, "**** is this one of those racers edge heads" that tells me that RE was leaps and bounds ahead of CT at that time.
Of your two choices I would have picked Ron Hamp but I would pick racers edge, Dynomite, OCP, dasa, Morgan, and sparks before Ron
Discussion Starter #6
Did you ask Allen?
He said racers edge was more expensive so that’s why I was going to pick ct, and I don’t have a whole lot of a budget, and I value everyone’s advice that’s why I’m posting so much, what is your top choice for around the same budget, and who is Allen??
Allen owns CT
On a budget I would call Matt at dynomite. He's a great guy and builds some awesome motors. I don't do valves nor do I have a dyno to test the results, my gut tells me there can't be much of an advantage to a 5 angle. I let racers edge do what ever they felt would perform the best with the porting they did, but RE didn't break down the price of porting and valve job.
A 3 angle should last longer due to the wider mateing surface but a shop can also cut a wide face and 4 thiner ones.
I would like to see flow numbers on a 3 and a 5. It might be out there on the net somewhere if you wanted to do some searching. Like has been said I doubt any shops have dynoed a build with both 3 and 5 angles but I'm sure they have flow tested both.
If you really want CT ask some questions, maybe he can show you some dyno numbers from his builds and give you an idea of what you're getting for you money.
Last time I checked RE charged $500 for porting and a valvejob. You're at $542 with CT. Did I miss something? If you're truly on the hunt for power, their entry level head will lay the pipe on any CT head.
To actually answer your question... the X number of angles on a valvejob is a gimmick. When you have the throat percentage set and where you want the valve face/seat set at, there is only so much room to put angles on the seat. The more angles you try to put in that distance, the shorter they're going to be. The length of the angles is more important than the amount. A head with a larger throat percentage, and a standard 60/45/30-33 can easily outflow a head that you tried to put say a 88/75/60/45/30-33 on. Are there other heads that that works well on, yeah. A TRX, not so much.
Discussion Starter #12
Thanks
1 - 12 of 12 Posts
