Hey all....I am wondering if anyone knows what the thickness is for a 97mm Cometic 3 layer head gasket?
Actually... for that matter...I need to know the thickness of a stock OEM 94mm head gasket is too :dunno: ....I had that written down somewhere but can't find it anywhere :11doh: .
I am adding a 97mm ESR/Wiseco 12.5:1 piston and 97mm Cylinder Works cylinder to my 04 that already has the HR+3 and Wiseco 13:1 and I would like to know if the Cometic gasket will reduce my compression even further.
I may even want to try a 2 layer gasket to bump it back up to be equal with my current setup...so I guess I will need to know the thickness of the 2 layer and the availability?
Any help would be greatly appreciated :yes ....thanks
