1 - 7 of 7 Posts
The rev limiter hits way to early. I was told I needed a new cdi box so before I went and bought a new one I put a stock one on and see what happened. Rev limiter is still the same. Then I was told I needed a stage 3 cdi. I have an Hmf pipe and from what I know the jetting was tweaked. Would the stock cdi still not work with those modifications? Would the stage 3 cdi fix my problem?
its not the cdi, its likely a jetting issue.
if you have an 04-05 an exhaust and open air box 180-185 main jet, 06+ 160-162 main jet. Also if the motor has work done to it, it will rev up much faster and you can generally fix that with gearing.
Exactly, it is not the CDI, or more correctly, the ICM.
if you are hitting a false rev limit you are likely too rich on your main jetting.
Discussion Starter #5
Thanks for the info. Also I was looking at some cdi’s and aren’t you able to program it to match the jetting?
No, you can buy a programmable CDI with several different curves, but since this is a carburetorated bike you can tune it really liek say a power commander does on a fuel injected bike. Your issue lies with jetting, take the bottom of the carb off and see what jets it has. Take pics as well and report back
Discussion Starter #7
I agree. When I bought the bike the guy told me it is very easy to flood so the carb is probably the issue
1 - 7 of 7 Posts
