1 - 2 of 2 Posts
I have a 2006 trx450er and I believe the green light is to tell when its in neutral atleast on the past quads I’ve had but my the green light (neutral light) stays on in every gear how do I fix this?! I don’t need to fix it but I would like to just to.
It's the Space launh Light when it is Green all the time it means that if you do a wheelie it will activate the intergolatice rocket booster and you will shoot up into space at 3000MP and when you leave the atmosphere everyone will see a huge light ring that closes up on its self.
Joking aside....
Is that fan bu chance wired to be on all the time? I ask this because usually if it is the RED light will stay on at all times and it's possible someone might have switch the bulbs around by accident.
If that is not the case check the netural Sensor wire to make sure it is not grounded or chafed through somewhere. It the Light Green and Red Stripe wire down by the Shifter.
1 - 2 of 2 Posts
