You will have to change the jetting to run the stock exhaust look up stock jetting on the search bar and that should get you a few results, may I ask why you chose to go back to a stock exhaust?I have a 2006 trx450er here in San Bernardino California (socal). I got it with a white brothers full exhaust not sure what size jetting, has regular foam air filter with lid and everything. It was running perfectly fine no bogging issues or anything. One day my muffler broke along with my starter clutch. I bought a stock 2007 trx450er full exhaust , installed it and then bump started my quad (starter button was broken) i only rode it for about 2-5 mins with the stock exhaust and it ran perfectly and idled perfectly. I then let the quad sit for a few weeks as it was broken and I was waiting for shop to rebuild the top end and starter clutch. Now that they rebuilt it and it starts perfectly, I’ve came across a new problem. Everything is perfectly fine up until about 30 minutes into riding it, after it’s been on for about 30 minutes it doesn’t idle at all. It starts up first try (if I slightly tap the gas) but just doesn’t idle on its own. It does run better with the choke on. The header glows crazy red. When I first start it up while it’s cold everything is good but 30 minutes in, it’s a disaster. Like I said this was my first time riding it with the full stock exhaust because it use to have a full aftermarket exhaust. Now that I’m on the stock one and it doesn’t want to idle after 30 mins, muffler glows red, only runs on choke after 30 mins, do I have to make carb changes now that I made the switch back to full stock exhaust? Never messed with jetting but if anyone has tips for me I’d appreciate it. My instagram is @250rick if I don’t respond soon enough
