1 - 10 of 10 Posts
Hey I’m new here and don’t know where to post this but I split my cases on my 2005 trx450r and took the trans apart and lost the spring that goes over the long dowel (shaft b) the override spring is what I think it’s called and I need some help locating one can anyone point me in the right direction?
Part 17 or 19? Part 17 is part number 24435-MEN-A10 and part 19 is part number 24651-MEB-670. Both parts can be ordered new from many different online retailers or found on eBay.
151853
That spring is there because he has an override transmission you will need to get it from a shop that does overrides.
An option would be to measure the the wire diameter and coil per inch and see if Mc Master Carr has something. You will more than likely have to cut it to length
He only thinks he needs it because he saw it in the video. He doesn’t need the spring.
1 - 10 of 10 Posts
