What kind of fuel issue are you having? The stock carb will deliver more than enough fuel for the simple mods you have.
It bogs out, have to give it quarter throttle to start. it will stall at idle. It will dump fuel out the float. float constantly gets stuck. I have rebuilt it twice myself and ive sent it out to get rebuilt.What kind of fuel issue are you having? The stock carb will deliver more than enough fuel for the simple mods you have.
What jets do you currently have in it, and are you sure the float is at the right height/angle. I had the same issue rebuilt my carb and nothing was working ended up being the float was not adjusted correctly. 8mm is the the correct height, i agree with hoser the 04/05 carbs are fine (more simple than fcr but good) an fcr carb new will run you 7-800, unless you can find one used. But give us your jet sizes and go from there.It bogs out, have to give it quarter throttle to start. it will stall at idle. It will dump fuel out the float. float constantly gets stuck. I have rebuilt it twice myself and ive sent it out to get rebuilt.
I hope your not hitting the throttle while cranking this is a sure way to take out your starter clutch. Welcome to the forum!It bogs out, have to give it quarter throttle to start. it will stall at idle. It will dump fuel out the float. float constantly gets stuck. I have rebuilt it twice myself and ive sent it out to get rebuilt.
