1 - 1 of 1 Posts
Located in Orange County, CA...
I'm selling a 2004 Honda TRX 450R titled and green-sticker (currently registered) frame, built motors, stock parts, and performance parts as a single package for someone looking for a build project at a discount!
Everything included in the package is listed below and totals well over $6000 in value. There are also additional OEM factory, aftermarket and maintenance parts I'm sure I am forgetting to list that will be included for the buyer.
I am asking $3800 for everything!
I will also entertain trades for anything interesting you may have
Package List:
04 motor w DASA head
04 titled frame 04 subframe
04 rear end
05 motor no head CP piston
04-05 crank/rod/venom piston
04-05 crank/rod
FCR carburetor
axle, carrier, hubs, locknut, rotor, etc
stock carb
stock ignition box
IMS clear desert tank
powermadd handguards RPM h/bar clamp
Aluminum skid platecut for Teixeira Tech Linkage - lots of scrapes, functional
04/05 Stock swingarm
Silver Aftermarket hood
Black stock 04/05 hood
Black stock 04/05 hood Stock heelguards
Rear aftermarket grab bar
Stock 04/05 headlight
Stock case saver
06+ Intake tube with UNI filter
Aftermarket Red Anodized handlebar clamp
ESR Red Anodized brake reservoir and throttle billet covers
Throttle assembly with ESR billet red cover and billet lever
Janssen Outlaw e-brake blockoff plate - red anodized Stock clutch lever
Stock clutch lever
Stock brake lever
Stock 04/05 linkage with extra dogbone
Stock pegs
Billet thumb lever
Stock handlebar clamps
Stock e-brake cable
Stock airbox lid
Aftermarket airbox lid with hole
Front A-arms set with one loose tie rod
Front fender stays
Rear fender stays
Front stainless braided brake line - for +3 arms
Pro Peg Nerfs
Pro peg mounts with solid aluminum heel buckets. I believe these are AC - very heavy duty. Scrapes, dings, dirty
AXE red anodized chassis skid - scraped up on bottom but perfectly functional
Stock 04/05 seat
Stock 04/05 Gas tank
Stock Rear 04/05 Plastic - black and in great shape with mounts and petcock - no hardware
Stock Rear 04/05 Plastic - red and in excellent condition - no cracks or other damage
Front 04/05 radiator shrouds with Cut fenders - heavy use, functional
Front 04/04 Stock Radiator Shrouds with Stock front fenders - heavy use, functional
1 - 1 of 1 Posts
