1 - 8 of 8 Posts
Alrighty fella's. My Hubby wants to know were he can get a 12 to 1 piston kit for his 450R? Any help would be great.
Thanks
Here ya go Sparks Racing
Personally though, if I were going to go to the trouble of installing a high compression piston I would go straight for the 13:1 piston. Your already going to have to have a mix of race gas and 93 octane for the 12:1 to run safely so why not just do the 13.8:1 and run straight race gas? talk to Woodward racing, one of the boards sponsors. He carries Sparks stuff and maybe able to get the piston cheaper.
O and BTW, I saw this 13:1 JE on Ebay this morning. Its going for pretty cheap too.
13:1 piston on ebay
Thanks
I wish my wife would buy me a piston....Im the one always buying things for her KFX700.....
Originally posted by desert_450r@Jul 30 2004, 09:04 PM
Hey guys, why do we have to run race gas at 12:1 when the YFZ has a sticker on the tank that says 91 octane required minimum and it has 12.5:1 ???
its a good idea?? I dunno but anything over 11.5:1 or so I mix race gas just in case my jetting is a little lean so I dont detonate my mill on the trails. Im just used to running cars and a lot of the logic and things I have learned screw with me. But I have seen alot of cars running aluminum heads detonate running 93 and 11:1 compression so that is why I said that. I suppose you can run 91 if you really wanted to but why chance it?
The yfz spects are 11.9:1, but i think that 93 pump would be ok up to 12.5:1.
Laz at GT Thunder told me he would recommend the use of race gas on any higher compression piston on the 450r motor.
Originally posted by desert_450r@Jul 30 2004, 09:47 PM
We're running that horsecrap 91 RFG here nowadays so even 92 is off the menu ... (A big reason I keep a couple gals of Xylene around) ...
And here I thought I read in DW the YFZ was 12:1 or 12.5:1 ... Hmmm ... O well ...
I forgot that some places don't have 93 pump anymore... maybe you could start a business on the downlow running 93 pump across the state line. :lol:
Oh yeah, i got the 11.9:1 spect from the yamaha site... but it may just be for the '05s.
1 - 8 of 8 Posts
