+ 1 steering stem
830 Views 4 Replies 2 Participants Last post by  mx333
if i get a +1 stem will i need to extend anything.
1 - 5 of 5 Posts
No you should not need to depending on your bar setup.
No you should not need to depending on your bar setup.[/b]
well i know my brake is long enought because i just got a new front end with steel braided brake lines.
Your good to go then no worries you can run Atv bars or CR high bend.
i run a +2 with cr high on one bike with stock lines so you should be fine
1 - 5 of 5 Posts
