08 450er wiring and fuse problems
211 Views 2 Replies 2 Participants Last post by  landen
dose anyone know where this wire goes the qaud runs but i have to jump start it the wire is red and is coming off the fuse box and the only electrical thing that doesn’t work is the fan+ blows insane amounts of fuses
Automotive tire Motor vehicle Automotive design Pollution Gas
1 - 3 of 3 Posts
I am at work right now but I dont think that is OEM. I would bet it ran some accessory or was installed as a jumper to go around the short but this is at best a guess. I believe all of the wires running from that fuse box are ran inside those two looms you show in the picture. When I get home I will check and post a wiring schematic from my manual to help. I recently dealt with electrical gremlins, what a bitch, but I followed the service manual guide. I found out my rectifier was causing a bunch of my issues. Do you have a service manual? If not I can post those pages as well. Good Luck figuring out this issue.
  • Like
Reactions: 1
i have a manual and it didn’t show anything i bet it was aftermarket thanks for the help
  • Like
Reactions: 1
1 - 3 of 3 Posts
