1 - 6 of 6 Posts
Hey guys I’m kyle, new to the forum.
I’m going to rebuild my top end, still runs but I’ve had it since 08 so I just wanna get some fresh parts in there. My question is I bought it with the HRC hop up kit in it already so do I have to buy any special parts or will just a normal rebuild kit be fine?
Just out of curiosity, when you say rebuild your top-end, what all are you planning on doing?
As far as parts, no, you don’t need any special parts to rebuild it.
Discussion Starter #3
I just mean piston, rings and gaskets. Just wasn’t sure if any of the HRC kit needed/should be replaced also.
Thanks man
No, no special parts needed at all. Throw a CP piston kit in there with a Cometic or OEM gasket kit and call it good. And if you have a lot of time on the machine it wouldn’t be a bad idea to have the head gone over as well.
Discussion Starter #5
Thanks man, I’ll have the head gone over too. Thoughts on replacing the timing chain while I’m in there?
yes timing chain and tensioner need to be done for sure and guides should be checked
1 - 6 of 6 Posts
