Yes, the stock has not adjustments on it, its factory set, the HRC needles are adjustable with different E clip settings and a different taperI just received an HRC needle for an 06 and it looks VERY different from my stock 07 needle. Will the non-nail headed 06 needle work in my 07 without complications?[/b]
Thanks for the help. I've got that much figured out already, but the 06 HRC needle head is completely different than the 07 one. I put the 06 one in and it seemes to run just fine, so I guess that it works :smiling:Yes, the stock has not adjustments on it, its factory set, the HRC needles are adjustable with different E clip settings and a different taperI just received an HRC needle for an 06 and it looks VERY different from my stock 07 needle. Will the non-nail headed 06 needle work in my 07 without complications?[/b]
