1 - 3 of 3 Posts
I just adjusted the valves and cleaned the carb and now I’m getting a bog when I stab the throttle. I’m running the following set up..
HRC Kit w/HMF slip on
162 main jet
42 pilot
55 leak
Needle clip 4th down
R&D fuel screw 2 turns out
Wheeler runs great but I can’t seem to get rid of the bog, any suggestions would be great. Thanks
I would look up the zip ty mod and also try timing the acc pump. The leak jet might need some changing and some people run the Boysen quick shot to help it some. I am guessing with the hrc kit you have no air lid?
1 - 3 of 3 Posts
