1 - 12 of 12 Posts
I had the baffle out and no airbox lid with the k&n filter but now i put the baffle and arrestor back in and the air lid back on to make it quiet again which is why i need the stock jetting for it. I think all i did was change the main jet and it is running fine now until you hit WOT, then it runs crappy, im guessing its running rich.
06 had a 121 main
tks., i've allway's been off one click.... :crazy: :_specialED:
mine was like a 118 and its an 06
now its a 162 i think that came with the hrc kit
stock 06/07... 120 main, 42 slow (pilot) jet, about 2 3/8 turns out on pilot screw, 70 leak jet, NHHU (non adjustable) needle
stock 04/05....118 main, 48 slow jet, unknown (adjustable on mid clip) needle, and non removable leak jet...
Discussion Starter #9
It had a 185 main in it so i only dropped it down to 165 and it runs great. Maybe the green wire mod and k&n air filter are whats making it want more fuel.
I personally dont think so........ but then again... not sure why it needed a 185 either.... unless someone mistakenly jetted it like an 04/05 machine...
hey, if you like how she runs... who cares what is stamped on the jet.... thats my theory, BUT, a 165 is a bit much IMHO, when using the stock air box and LID ON.....
jmho.....g
Discussion Starter #11
jmho.....g[/b]
I agree with you on both. Id rather it run rich because its my practice bike and the longer it runs the better it is for me.
Ok I just installed the same jetts on my 06 450er runs great unless I hit gas hard it has a bog what do I need to do
1 - 12 of 12 Posts
