2006 trx450er (gutted exhaust, athena 500 big bore)
I was doing some digging and came across the popular “green wire mod” for the 2006+ er models. For those that don’t know what it is, it’s a mod that takes the rev limiter from 9800 to 10800 and may change the time if curve (not sure on that one). You do this by cutting a green wire on the Very left plug on your cdi. Could I run this with an Athena 500 big bore? Would it hurt anything on a 500 big bore? And would it be worth it? Also what’s the point in it… if you look at any dyne chart you have peak hp and then it starts dropping. The rev limiter usually limits right at the peak power. So adding 1000 rpm’s to the limiter would just hurt you more than help when it comes to acceleration? Is this just for a higher top speed? Sorry for all the questions. thanks anyway tho, Korbin.
