21 - 32 of 32 Posts
Yea thats what ive been coming across online. Sucks man i just want to ride.so if i tear it down and send it in to some1 what am i expecting to pay?
300 or so. Might as well port the head while its out.
Consider the following shops for the work: Racers Edge, Oregon Coast Powersports, Dynomite performance, Dasa, Demon.
Ok i think im gonna go with racers edge shop for the turn around time. So do my valves need to be re seated or do i need new valves in general. Can i keep stock springs? And should i do +1 valves all around with
Take your pick
Check back often for new specials!
For November/Decemeber we will be having a special on our 06-08 TRX 450R Gen.1 CNC heads. Heads are cut in-house with a MillPort 5 Axis, and price will include a CNC valve job as well.
The special price will be $425 with a valve job. Plus size valve seats are no extra charge. We do recommend stepping up to +1 Exhaust valves.
Add these items:
Ferrea Stainless Steel Valves - $35 ea.
KibbleWhite Dual Spring Kit - $185
HC3 or Web 208/921 - $155/$285
11,12,13,13.5, 13.75:1 CP Piston - $185
Gasket Kits - $65
Carb bore - 42.5 ($150) 43.5 ($250)
Complete Head Special: CNC Porting, 4 new Ferrea Valves, KW Spring Kit - $675
Also have big bore kits, etc available.
Turn-around time: 2-3 days.
LTR, YFZ, Rhino, Raptor 700 CNC Porting also available.
Please email or call for more info. 520-631-0797
Can also contact Morgan/ocp/Mixxer etc
Give them a call or email, they will know whats best. Personally I like upsizing the exhaust valves (usually needs to be done anyway) and a good port.
Yea il give them a call its just a little out of my budget right now but i dont want to put it back together then tear it out later.
Better to cry once my friend.
To Cold start start mine I pump the throttle 10 times (it's in the owners manual) then full choke and crank.. If it starts and stalls, I pump another 2-3 times then crank her up again... I live in Canada and she starts no problem in -20 celcius..
All HRC mods except the cam. Shell Rotella T6 - 5w40
Dam dude what do you wear for ridin gear a survival suit from the coast gaurd & an astronaut helmet?
Discussion Starter #29
So i got the head off and its goin to the local shop tomorrow not sending it out cus all im gonna have done is new valves maybe springs. Does everything look normal in these pictures?
Discussion Starter #30
So i started a new thread in engine forum . But its still not starting after new intake valves put in by a local shop. I got .006 on both intake valves timing marks lined up carburetor cleaned new spark plug new gas. Seems like the first touch of electric start almost fires up but then its not close after that. I had the battery connected to my truck for good cranking amps still nothin. Im supposed to go riding this weekend ... if i cant figure it out tonight or tomorow im not going
21 - 32 of 32 Posts
