1 - 4 of 4 Posts
Going back to college need money for tuition Hate to sell this quad but gotta do what ya gotta do. Okay, Have an 2005 450r, Red. Excellent condition, oils/filters changed/cleaned every other ride. Motor is just rebuilt by BCS Performance in March! Hauls *****!!!! BCS Had the whole quad, tore the motor down and they did all the work. Everything was tuned on the dyno by them. You can check them out at BCSperformance.com. They Sponsor NEATV.
Asking: $5,500 OBO
Motor:- ALL motor work done by BCS Performance*
CP Pistion: 12:1 Compression 94mm (Stock Bore)
Web 208 Cam
Rossier Exhaust
+1 Exhuast Valves
Uni Filter
Complete New OEM Bottom End
Crankshaft has Knife Rod.
CRF450r AMPCo 45 Intake Valve Guides
New OEM Clutch Kit (Springs/Fibers/Steels/Gaskets)
Body:
Red Plastic
Black Powder Coated Frame
Black Power Coated Sub-Frame
Black Powder Coated Swing-arm
Bare Gusset Kit
Nac's Racing Number Plates
PowderCoated Motor/Fender Mounts/Brake Hub/ Rear Hubs
Gunnar Kill Switch
LSR Parking Brake Block-off Plate
Quad-Tech Hood
IMS Classic Bumper w. Removable Aluminum Number Plate
Suspension:
Houser+2 A-arms
DiRisi Revalve & Re-Sprung Front Shocks -Triple Rate,MX 200lb B Class Rider
Rear Shock Revalve & Re-Sprung- Dual Rate, MX 200lb B Class Rider
DiRisi MX Linkage
LSR Axcalaber Axle
Denton Steering Stabilizer
Controls:
Gibson +1 Steering Stem
Gibson Bar Clamp
Pro Taper Bars
ASV F3 Clutch Perch & Lever
08 Clutch Cable
Renthal Grips
*Stock Stem w. Renthal 7/8 bars & Renthal grips*
Tires/Wheels:
Kenda Klaw MX Front
Kenda Klaw Mx Rear
ITP T-9 Baja Fronts
Douglas Bearlock Rear Rims (8in Rim)
Holeshot MRX4 Rear
Drive:
Renthal 14t Countershaft Sprocket
JT 37t Rear Sprocket
DID ATV X-Ring Gold Chain
Tsunami Brake Rotors All Around
TM Red Chain Roller
Renthal 13t Counter Shaft
Armor:
PRM Belly Pan
PRM Swinger Skid
Misc:
SRP Brake Line Clamps
PC Throttle Mount
Clear Vent Hose
New Heat Tape
New Brake Pads All Around
New Swing-Arm/ Steering Stem Bearings
Run Bel-Ray* Thumper Engine Oil 10w-40 & Honda 80W Transmission Oil
Maxima Filter Oil
OEM Oil Filter
Stock Heat Shield Mounted on Head Pipe
NOTE* IN THE PICS THE HIPER RIMS DO NOT COME W. THE QUAD*
http://i9.photobucket.com/albums/a95/Holes...15/164_9150.jpg
http://i9.photobucket.com/albums/a95/Holes...15/164_9148.jpg
whats the deal mike, why you selling? You looking at marks 450?
Free bump on this.. this quad is sick, the susp works as good as my LT and his engine smokes my 06 anyday.
1 - 4 of 4 Posts
