21 - 37 of 37 Posts
Discussion Starter #21
Later on when I get the funds it will have new tires and new either headlock rims or those as rims
Discussion Starter #23
So I just got my 04/05 head on but the upper hangers still dont line up do i have to pry them all in place or should the bolt just slide in?? Also should i have to cut down the collars that go on?? This is what it looks like on my quad
151614
151615
How much are they off? Make sure you keep the bolts that hold the plates on loose until you get the long bolt through. Are the other three motor mount bolts in already?
Discussion Starter #25
Ya all the other bolts are in but I had tightened them all up even the swing arm bolt. Should they all be loose too?? That top bolt is of a good 1/2 - 3/4 inch.
I wonder if you have the hangers for the other head on there and the bolts and spacers for the same as well.
Discussion Starter #30
Bolts and spacers are brand new for an 04. They also didnt fit for the other head too.
what about the brackets?
its possible you may have to loosen the mounts a bit to fit everything on there as well. the spacers just look too big though which is odd
Discussion Starter #32
The brackets are the ones that came with the quad. I will try loosening all the bolts and try to put the tip bolt in
perhaps they are brackets for an 06? something just doesnt add up.
also curious they arent on backwards or the wrong side are they?
Discussion Starter #36
I dont think they are backwards, any other way and they will be way off. The way they are in the pictures are how I have them.
21 - 37 of 37 Posts
