04-05 seized engine/tranny-
686 Views 10 Replies 7 Participants Last post by  shadbehnke
How much is an entire engine w/tranny worth? The motor seized & haven't opened it up. From what I heard it ran great & then seized. I found another engine so I just replaced the entire unit. This one has a stage 1 in it. This was rebuilt 7 months ago w/new crank & clutch. Tranny was fine. Is this worth $600? Location-Phx, AZ 85018
SOLD-$150
1 - 11 of 11 Posts
Yeah if its a running engine and no issues, well worth it for 600
depends on whats wrong with it if it's worth 600, i would open it up and see whats wrong but thats just me
im confused are u asking if the seized engine is worth 600 or the new unseized engine is worth 600?
im confused are u asking if the seized engine is worth 600 or the new unseized engine is worth 600?[/b]
hes asking if that motor pictured which is seized up is worth 600$
I'm asking what's this worth as a whole package (seized motor but unknown damage)? Might be worth it to tear it down but once I open it up, other than a piston or rod, I would have no idea how bad it is. Don't know anything about the inside of the engine. Assuming everything is toast, what's a tranny worth?
I'm asking what's this worth as a whole package (seized motor but unknown damage)? Might be worth it to tear it down but once I open it up, other than a piston or rod, I would have no idea how bad it is. Don't know anything about the inside of the engine. Assuming everything is toast, what's a tranny worth?[/b]
I would be interested in it if you took off the top end to see if it's a piston or crank cause if they look good maybe it's the tranny or somethin in the clutch i would want to see the top end pulled off then i could tell you what i would pay for it then, Thanks Skyler
if its siezed its not a big prob. if its the crank it could be very big problems and close to nothing.....
200.00!!!!!!!!!!![/b]
ill give ya 300.
1 - 11 of 11 Posts
