1 - 18 of 18 Posts
will a 04-05 hmf exhaust full exhaust fit onto an 07 450r ???
thanks
I know the TC-R is the same through all years, and I think the shorty is the same for all too, but I also heard they don't, ill have to try to put my short can on one...
What is Different from first Gen to second gen as far as the exhaust is concerned?
Eric
have you tried this? I know a DASA wont for sure...[/b]
really? i was unawared why wont it fit what was the problem?
maybe only some exhausts will fit
and um i think someone just hacked my CPU lmao BRB
it will not fit...with alittle mod the can will fit but the header pipe wont ever come close...atleast with my buddies lrd it would not even work after he cut and welded it
Discussion Starter #10
it will not fit...with alittle mod the can will fit but the header pipe wont ever come close...atleast with my buddies lrd it would not even work after he cut and welded it[/b]
hey thanks alot guys for all your hints and info !! its much appreciated...now i know not to get an 04-05 pipe for the 07 lol....
I was unaware they were that much different, what did Honda change to make it that way? Is the exhaust port in a different location? I thought the frames were almost identical...
Eric
will not fit at all completely different motor
Stock 05 450R
Eric[/b]
I think the subframe changed as well as the angle of the exhaust port.
the silencer mounts differently too, on the 06 and up, it mounts to the grab bar.
I was able to get a White Bros. E2 slip on on mine with the HRC header. So, a slip on will should work, but a full system wont.
never tried it but from what ive heard is the exaust port angle on the head is diffrent, and are the pipe silencer mounting points.
i thought i saw a guy on here 2 yrs ago do a sparks 05 system on a 06. and he said it fit like a glove :ermm:
I have a HRC system on my bike. A guy on here has a yoshi RS-7 F/S On his 05 and i have a buddy with a slip on Dr.D off an 05 on his 06.
-Kip
1 - 18 of 18 Posts
