clutch slipping in 4th and 5th gear on my 2005 450r - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 07-10-2019, 12:30 PM Thread Starter
so when I bought the bike I noticed the clutch slipping in the higher gears so I ordered some new clutches. anyone else have that issue ? also do you guys run synthetic on both sides ? im running lucus 10w40 synthetic
randystone450r is offline
post #2 of 3 (permalink) Old 07-10-2019, 02:55 PM
Slipping in high gear is a worn clutch usually, hopefully the new one fixes it. Be sure to look at the pressure plate and basket for wear or warping. I usually run rotella non synthetic on the clutch side or mobil delvac.
04 450r
duke416ex is online now
post #3 of 3 (permalink) Old 07-10-2019, 05:10 PM
Making HP ainít free. . .
hoser's Avatar
Make sure your clutch is adjusted properly, an improperly adjusted cable can cause clutch slipping.
hoser is offline
