Problem with reassembling rear brake caliper. - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 5 (permalink) Old 06-05-2019, 08:57 PM Thread Starter
Hi I had to take apart the rear axle and reassemble. It was going well till i had to reinstall the brake caliper. There is no way of fitting the caliper onto the mount bracket, it has no space between the mount and the disk. Take a look at the photos, does anyone know what i am doing wrong?
ElLoco is offline
post #2 of 5 (permalink) Old 06-05-2019, 09:13 PM
450hrc's Avatar
I would bet your axle is not all the way in (as in needs to go more towards the right side of the quad). Take a tape and pull off centerline of the swinger to the end of each axle and see if your measurements are equal. Your brake rotor is riding way to close to your swinger.
450R NEVER ENDING
450hrc is offline
post #3 of 5 (permalink) Old 06-05-2019, 11:44 PM Thread Starter
you're right! thanks so much
ElLoco is offline
post #4 of 5 (permalink) Old 06-11-2019, 10:52 PM Thread Starter
Even with the axle moved into place there is not nearly enough room for the break caliper to be mounted. There is clearly something wrong with the spacing. is there a spacer that needs to be between the mount and disk?
ElLoco is offline
post #5 of 5 (permalink) Old 06-11-2019, 11:00 PM Thread Starter
what is supposed to fill this gap on the axle?
ElLoco is offline
