My quad will go into gear without clutch and barely moves - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 1 (permalink) Old 06-09-2019, 09:22 PM Thread Starter
I have an 07 trx450er . I took my clutch apart to inspect it and put it back together and now I can put the quad into gear without the clutch and it doesn't stall but when I give it gas it barely moves and the engine revs up. Also is the clutch lifter on the push rod supposed to but up right against the lock washer? I noticed my didn't, it had a little gap and I put my finger against it and pulled in the clutch lever and it barely moved and my clutch lever didn't bounce back properly even with my finger pressed against the washer. Also my manual said the last pressure plate should be rotated slightly into the notches on the clutch housing arms but the videos I watched on you tube they put it in order with the rest of the plates? Any help would be greatly appreciated.
Jelia2239. is offline
