Sprocket and Rotor Hub Grooves - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 05-14-2019, 06:51 PM Thread Starter
My axle got a little play in it after my last trip to WV. I pulled the carrier out and to my surprise, only one bearing was bad (it was toast, but i still changed all 3). I guess I shouldn't be too surprised though, the machine is still on it's original 2007 brakes, chain and sprockets.
I am concerned about the sprocket and rotor hubs, however. They have some grooves that look machined in but i would assume the surfaces should be smooth and flat so the seals can have a flat mating surface to keep water/dirt out.
I found a replacement rotor hub on RMATV for ~$45 but it looks like the sprocket hub can only be replaced by buying a new axle. My axle is straight and I really don't want to spend $250+ because of these little grooves if they're supposed to be there or if there is a way to replace the hub separate from the axle.
Anybody have any insight?
basackwards90 is offline
post #2 of 3 (permalink) Old 05-14-2019, 07:07 PM
CJM
CJM's Avatar
I had the same thing happen once, I just bought all new stuff and a used axle off ebay.
-2006 450R. New WHIP..
CJM is offline
post #3 of 3 (permalink) Old 05-14-2019, 08:50 PM
i had the same thing happen the carrier bearings were toasted on one side on i just bought a new axle and the brake rotor hub and a lonestar billet rear carrier and it is the tightest rear end out of all of my bikes. It is just when the bearings wear out and get lose and wear those parts out i went with the dominator 2 plus 4 axle for mine around 500 for all of it but well worth it it can corner way better and looks a lot better
2005 honda TRX450r
Colin is offline
Similar Threads
new oem 04/05 trx450r aarms ,axlew/sprocket hub/ axle nut, rear brake rotor hub easman31 Parts/Accessories 0 08-06-2011 11:16 AM
new oem 04/05 trx450r aarms ,axlew/sprocket hub/ axle nut, rear brake rotor hub easman31 Parts/Accessories 0 07-30-2011 04:18 PM
04/05trx450r new rear rotor hub/ axle nut/transmission/inner clutch hub&pressure plat easman31 Parts/Accessories 0 06-20-2011 12:28 PM
'06 rear rotor & rotor hub fit on '04? bk111 Suspension, Chassis, and Drivetrain 1 06-08-2010 05:41 PM
Needle has no clip grooves 951bulldog Engine 1 10-07-2009 02:03 PM
