Outlaw racing clutch lever Question - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 4 (permalink) Old 02-17-2019, 10:47 PM Thread Starter
Ryan DeGraw's Avatar
Hey guys, I just bought a new clutch lever and Motion Pro cable, This thing is now harder to pull now that I removed the stock cluster. The old one had a ton of play and I wasn't going to use the parking break so I removed the old assembly, is there a way to adjust this differently? Or is there anything else I can get cause this sucks and I have a race coming up in two weeks.
Also I just cut the Neutral wires, can I spice them together? I can't start in any gear, like I can my Kawi. I have to be in Neutral. What are you guys using to get an easier clutch Pull?
Ryan DeGraw is offline
post #2 of 4 (permalink) Old 02-17-2019, 10:54 PM
CJM
CJM's Avatar
Splice the wires together. As far as making the clutch lever easier to pull, try adjusting it to have more slack and change where it grabs. I have mine to grab about halfway out
-2006 450R. New WHIP..
CJM is offline
post #3 of 4 (permalink) Old 02-17-2019, 11:06 PM Thread Starter
Thanks CJM. I will try that out tomorrow and splice them together. I went on a 4 hour ride for the first time and it was rough, can't wait to get my Flexx bars and new steering stem on tomorrow as well. I have to find out where to wire up my Kill switch too. I wish there was a way to get it to be closer to the bar itself as well. I'm super jealous of my friends ktm 525 hydraulic clutch lever.
post #4 of 4 (permalink) Old 04-09-2019, 10:26 PM Thread Starter
Figured out my issue I was having, someone prior installed the clutch fibers incorrectly. Not lined up and 3 fell out when I pulled the pressure plate off. One was even installed in the hub cutouts! Wtf lol. But time for a new clutch. Anyways problem solved and I no longer have the outlaw which is the same as mar btw.
File Type: jpg 7B134657-34C1-41B1-87DB-A8BA392C6D49_1554863125248.jpg (114.7 KB, 6 views)
Similar Threads
New clutch basket, issue with clutch lever. HELP! BlackMajik450R Suspension, Chassis, and Drivetrain 9 05-17-2013 12:46 AM
Me racing a outlaw 525 iJacob Engine 11 05-11-2013 02:58 AM
Holtz Racing Products Swing Arm with Outlaw style linkage - Honda TRX450 04-05 400ex4ever Parts/Accessories 0 04-24-2011 02:15 PM
WTB: Inner clutch hub, clutch basket and pressure plate spring/bolt and kick lever. itsmillertime Wanted 2 01-18-2011 05:23 PM
bustedazz racing on his racers edge trx 500 at outlaw sand drags in alabama w84me Lounge 11 05-26-2009 10:17 PM
