I have a 2006 trx450er, and everytime I try to start it, it makes a long whining noise as if the battery was diying and it would turn the motor over every once and a while. I put in a brand new starter clutch and reduction gear, and its doing the same thing. I was thinking maybe the brushes in the starter?
Take the side cover off and you will see what it is doing. If the clutch is spinning on the crank and only turning the crank over every now and then it is the starter clutch. Some times the reduction gears will mess up and not even spin the clutch but you can see what all is happening with the cover off. Does not sound like the starter at all if it is turning making the spinning noise.
Related Threads
Honda TRX 450R
1.2M posts
52.1K members
Since 2004
