Throttle sticking ... only when riding?! - Honda TRX Forums: Honda TRX 450R Forum
 1Likes
  • 1 Post By gboezio
post #1 of 6 (permalink) Old 08-20-2019, 02:47 PM Thread Starter
OK this is a weird one. For a while now it seems my throttle has been getting increasingly difficult to push and it feels sticky, not smooth at all. The throttle cable is not NEW but it's been replaced when i had my rings and stuff redone like 2-3 years ago. I know this sounds like a lot but I don't ride this bike all that much so realistically 2 years is not much riding, maybe like 50 rides or something?
Anyway, the other day i was driving and all of a sudden I COULD NOT push the throttle in any further, I must've been at 3/4 throttle or something. Seemed like the sticky throttle had been pushed to the extreme for a second. It lasted like 2 seconds and returned to just being crappy but that scared me a bit and I decided to investigate. I started by the simplest, took off the throttle housing cover and drenched that with WD40. Also shot some in the hole where the throttle attaches hoping that it would drip down in the actual cable. Felt SUPER smooth after that, much better than before. I thought job done and screwed the cover back on.
Next ride of course the throttle is weird again. Kinda baffled at this point. I just messed with it a bit and when the bike is off the throttle seems pretty smooth. Not as much as when i had just WD40ed the housing but still pretty good. I took the carb off and I'm going to tear it down to clean it and see if anything seems odd in there. Seems weird that it works relatively smoothly when not running but then when I'm riding it feels sticky and stiff.
Anyone ever heard of this? Doesn't make sense to me...
D3n1s is offline
post #2 of 6 (permalink) Old 08-20-2019, 04:28 PM
Hmm I would inspect the throttle drum that lifts your slide assuming that your bike has an fcr carb. Inspect the wheels on the slide, vacuum plate, and vacuum plate o ring. If everything looks good start with replacing the cable since that did somewhat help.
Rg450r is offline
post #3 of 6 (permalink) Old 08-21-2019, 07:42 AM Thread Starter
It's an 05, no FCR.
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Venom 12.4:1 97mm piston / Balanced Honda revised crank
Stage 2 hotcam
CRF450 clutch / CR500 springs / Trinity cover
UNI filter
Cut airbox lid w/ outerwears
R&D Fuel screw (2 turns out)
Jetting : 185 Main, 50 pilot, HRC needle third clip
Fox FLOAT Evol shocks / Lonestar DC4 arms
Pro-taper bars / Fly grips / Powermadd guards
Moose bumper
Maxxis Razr tires
D3n1s is offline
post #4 of 6 (permalink) Old 08-22-2019, 09:07 AM
gboezio's Avatar
Hi Denis, it must be vacuum related, when the engine is runing it pulls a lot of vacuum. I'm pretty sure it's carburetor related, maybe the drum is worn. Not a 2004-05 expert, but I would try it on the bench with a shop vac to see how it sticks.
Ryan94Wright likes this.
2008 TRX 450ER XC racing
FMSQ # 281
gboezio is offline
post #5 of 6 (permalink) Old 08-22-2019, 12:09 PM Thread Starter
is it time to get a bored FCR? :D
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Stage 2 hotcam
UNI filter
Moose bumper
Maxxis Razr tires
D3n1s is offline
post #6 of 6 (permalink) Old 08-22-2019, 09:50 PM
gboezio's Avatar
Yeah why not, bored but not boring lol
FMSQ # 281
gboezio is offline
