Jetting - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 5 (permalink) Old 07-18-2019, 10:24 PM Thread Starter
Jetting
I just swapped in my fcr carb. It has 180 main and 48 pilot. Starts up fine, still sputters a lot but once it is Wot it runs fine. It also backfires on deceleration. Which of the jets do I need to change?
The quad has a high compression piston, full dasa exhaust and stage 2 hotcam. The fcr carb is bored out to 42.25 mm
Noah_t is offline
post #2 of 5 (permalink) Old 07-19-2019, 12:12 AM
Cultcc00's Avatar
48 is too big for pilot, Someone else in here with more knowledge about your mods and jetting should respond but I think commonly people run 42, might need a 45.
Yes-it goes fast
No-you can't ride it
Cultcc00 is offline
post #3 of 5 (permalink) Old 07-19-2019, 10:57 AM
gboezio's Avatar
180 is big, never sen anything run fine with more than a 45, more of a 42 like suggested.
Decel popping means header air leak, change the exhaust crush gasket.
2008 TRX 450ER XC racing
FMSQ # 281
gboezio is offline
post #4 of 5 (permalink) Old 07-19-2019, 12:58 PM
Agreed ^^ 42 would be ideal for your mods.. I’d figure your main would be around 170 as well
Rg450r is offline
post #5 of 5 (permalink) Old 07-21-2019, 03:38 PM Thread Starter
Also runs on vp110 if that makes a difference in what jets I need to run, I was told to ask dasa so I did and the person told me to try a 200 main. That’s the first time I’ve been suggested to do that from multiple people
Noah_t is offline
