Won’t idle - Honda TRX Forums: Honda TRX 450R Forum
 2Likes
  • 1 Post By gboezio
  • 1 Post By Ryan94Wright
post #1 of 14 (permalink) Old 07-12-2019, 06:53 PM Thread Starter
Won’t idle
I was wondering if my intake valves were tight if that would cause the bike to surge and not idle consistently. It’s got a dynojet kit with a175 mainland a 50 pilot . Fuel air screw 2.5 turns out
randystone450r is offline
post #2 of 14 (permalink) Old 07-17-2019, 07:01 AM Thread Starter
anyone ???
post #3 of 14 (permalink) Old 07-17-2019, 01:25 PM
Have you checked the boots for intake leaks? Sounds like that’s what could be going on, that or your pilot jet may be clogged.
Rg450r is offline
post #4 of 14 (permalink) Old 07-17-2019, 01:34 PM
If you have a hanging idle this is what I would do
Look through pilot jet and pilot circuit to make sure nothing is clogged
Make sure all clamps are tight from the cylinder head to the air box
If it still idles bad spray around the carb to head boot and carb to air box boot.. if at any point when you are spraying the idle changes you have an air leak.
Rg450r is offline
post #5 of 14 (permalink) Old 07-18-2019, 04:49 AM Thread Starter
use starting fluid ?
post #6 of 14 (permalink) Old 07-18-2019, 07:57 AM
gboezio's Avatar
Dynojet kits are junk, stay away, use keihin jets
Ryan94Wright likes this.
2008 TRX 450ER XC racing
FMSQ # 281
gboezio is offline
post #7 of 14 (permalink) Old 07-18-2019, 09:30 AM
Starting fluid or carb cleaner is what I have used.
Rg450r is offline
post #8 of 14 (permalink) Old 07-18-2019, 06:12 PM
Yes the valves being out of adjustment will cause idle issues and hard start when warm.
04 450r
duke416ex is offline
post #9 of 14 (permalink) Old 07-22-2019, 08:11 PM
I do the same thing with Wd40. Its easier on rubber parts and wiring.
08TRXFoFiddyAKAMcNasty is offline
post #10 of 14 (permalink) Old 07-24-2019, 08:16 AM
Ryan94Wright's Avatar
What year quad do you have?
I think you have way to rich of a Pilot Jet because 50 Pilot in Dynojet brand is bigger then normal Kiehin jets. One trick to try is turn the Choke ON, now if that was a Success then you're Pilot jet is way to rich.
Dynojet 175 is equal to a 197 Keihin (OEM Jet)
Dynojet 50 is equal to a 57 Keihin (OEM Jet)
go with oem jets or at least use a Jetting Size Converter because Dynojets cause a lot of confusion.
If you clean the carb Dissemble the entire carburetor, take all jets and mixture needle out being sure not to loose the springs that go under the mixture needle aand so on, use compressed air (don't use carb cleaner if you have a FCR Carb)
gboezio likes this.
Build Break Rebuild Better
Ryan94Wright is offline
post #11 of 14 (permalink) Old 07-24-2019, 09:13 AM Thread Starter
My pilot is Keihin
post #12 of 14 (permalink) Old 07-24-2019, 11:14 AM
Is your bike 04/05 or 06+? If it’s an 06+ I would start at a 42 pilot jet.
Rg450r is offline
post #13 of 14 (permalink) Old 07-24-2019, 01:40 PM
gboezio's Avatar
50 keihin pilot lol and a 197 equivalent ?!? OMG if it's a FCR (06+) they have used numbers out of the 04-05 carbs.
And if it's a 04-05, yes the valves will cause the bike not to idle and be a pain to start.
FMSQ # 281
gboezio is offline
post #14 of 14 (permalink) Old 07-25-2019, 02:16 AM
I might have mis typed something Idk lol
