What size Keihn jet? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 06-22-2019, 02:44 PM Thread Starter
I have an 05 with a LEXX slip on, and I have a 125 main jet in it right now .... the bike is completely stock otherwise... I want to take the air box lid off and put an aftermarket filter on as well .... with the slip on exhaust, and air box lid, what jet set up should I have (main jet, pilot, and leak) ... THANKS!
Gear619 is offline
post #2 of 3 (permalink) Old 06-22-2019, 03:30 PM
Making HP ainít free. . .
hoser's Avatar
Try reading the jetting sticky at the top of the engine forum. That should help you get it dialed in.
hoser is offline
post #3 of 3 (permalink) Old 06-25-2019, 07:33 PM
CJM
CJM's Avatar
180-185 roughly. higher elevation from sea level you are, smaller jet you need.
-2006 450R. New WHIP..
CJM is offline
