05 ... New to the TRX, jet and mod help! - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 2 (permalink) Old 06-21-2019, 05:17 PM Thread Starter
I just recently purchased an 05 Trx450r for dirt cheap becuase the kid said it bogged when he mashed the throttle. It has a slip on exhaust that’s it ... ended up putting a 125 jet in it and it fixed the bog issue, so now the bike is in running order .... now I want to get into the basics of performance with this bike .... what are some easy mods to get some performance out of it and any supporting mods that go along with them ... not talking like throwing thousands of dollars into the bike just easy minor mods that giver her a little more performance
THANKS!
Gear619 is offline
post #2 of 2 (permalink) Old 06-21-2019, 08:42 PM
Cultcc00's Avatar
THANKS!
Remove air box lid and get an aftermarket air filter, hc piston, if you want to run pump gas 12:1 is about the limit, a different cam, I will put a link to a cam guide that has all the information about several cams, if you want to spend more money you can do an fcr swap which is the carb off the newer bikes and the same one the crf uses, it all depends on where you want the power, do you plan on doing it yourself or taking it to a shop and having them work on it?
https://www.trx450r.org/forum/93-eng.../topics/136727
Yes-it goes fast
No-you can't ride it
Cultcc00 is offline
