08 450r hard starting - Page 2 - Honda TRX Forums: Honda TRX 450R Forum
post #16 of 27 (permalink) Old 03-15-2019, 08:35 AM Thread Starter
Originally Posted by duke416ex View Post
You can set the decomp with a gap but best way to set it is with a compression gauge. E starts work best at around 60 cranking psi. The kicker will start fine at that psi too, but I think for just a kicker most set them around 100. If you get the e start working though you want it at 60.
I have a compression guage I'll try that. I done some research seems that backing the adjuster scre out gives it more compression and screwing it in gives you less am I right on that? Thanks for the advice.
Brandon79 is offline
post #17 of 27 (permalink) Old 03-15-2019, 09:08 PM
gboezio's Avatar
Yes backing up reduce the decompressor effect and increase compression, the compression tester check valve should be close to the head or will read lower
2008 TRX 450ER XC racing
FMSQ # 281
gboezio is offline
post #18 of 27 (permalink) Old 03-16-2019, 12:22 AM Thread Starter
Just set intake to .006 and exhaust to .011 set decomp to .017. Decomp was at .012 .Still had trouble starting, did compression it held good. Only thing I noticed is my filter that came on it seemed really dirty. Took filter off and just sitting ther it started first kick every time. Took a ride, thought I was good. But for down the road and I stalled lmao. Wouldn't start back. Pulled it off. Seems that my filter Is dirty. Gonna get a new filter and see where I'm at. Cleaned carb and made sure jets was clean. 148 main, 42 pilot, 78 or 75 leak.cant remember.
post #19 of 27 (permalink) Old 03-16-2019, 07:39 AM
gboezio's Avatar
Might be wort checking the stator, quitting while running and not restarting now sounds more like a failed stator, you can measure the resistance of the white/blue/black red to the ground (engine block) from the grey plug, and all those wires together while there. Wait until it fails to do so
FMSQ # 281
gboezio is offline
post #20 of 27 (permalink) Old 03-16-2019, 10:47 AM Thread Starter
Got my multimeter I'll try that today. Could you point me to the direction of those wires to check? It didnt just die last night though I actually stalled it out. Then it wouldn't restart. Seems to start better when it's cold or cooled off some. But with what I did I feel like it's better than it was. Thanks for all the help. Slowly getting this figured out I believe.
post #21 of 27 (permalink) Old 03-16-2019, 02:38 PM Thread Starter
Went out this morning choked it, fired first kick, has been since then but hasn't gotten good and warm. Gonna take a longer ride and let it get good and warm. Either way it's doing better than it was. Thanks for everyone's help it is greatly appreciated. Seems like I may have a few more issues to work out but I'm getting close.
post #22 of 27 (permalink) Old 03-16-2019, 05:03 PM
Making HP ainít free. . .
hoser's Avatar
Glad to hear you’re making progress with it.
hoser is offline
post #23 of 27 (permalink) Old 03-16-2019, 06:33 PM Thread Starter
I'm getting there, thanks to the people here on this forum. You guys are great.
post #24 of 27 (permalink) Old 03-17-2019, 05:29 AM
gboezio's Avatar
If it did not stall by itself, maybe it's not stator related, wires are the gray stator plug
FMSQ # 281
gboezio is offline
post #25 of 27 (permalink) Old 03-17-2019, 06:06 PM Thread Starter
Ok just wanted to give an update and thank everyone for their help. Put a RandD flex jet air fuel screw in it, New air filter, got it running adjusted A/F screw, set idling, and it starts a whole lot better now. First or second kick usually. Took a nice little ride today it was nice and warmed up by the time I got back, shut it off, tried starting it again warm two kicks and it fired. I think i finally have it where it should be. Again thanks for everyone's help.
post #26 of 27 (permalink) Old 03-17-2019, 07:28 PM
Cultcc00's Avatar
Awesome, glad to hear it’s running better for you
Yes-it goes fast
No-you can't ride it
Cultcc00 is offline
post #27 of 27 (permalink) Old 03-19-2019, 03:18 PM
gboezio's Avatar
Another good running 450R Cheers !!
FMSQ # 281
gboezio is offline
Similar Threads
hard starting 08.....any ideas? bcpaulie Engine 1 09-23-2013 08:44 PM
08 trx450r hard starting when hot 450Rape Engine 9 07-30-2012 11:03 PM
Hard time cold starting 05 450r 06450r Engine 3 07-17-2011 01:49 PM
Hard starting on 06 ER, jerks in gear, weird starting noises? hasteranger Engine 7 02-20-2009 09:30 AM
Hard starting when the motor is cold!! cumminpwr11 Engine 20 03-30-2006 01:04 AM
