05 doesn't rev out to redline - Honda TRX Forums: Honda TRX 450R Forum
 1Likes
  • 1 Post By phillybuilt
post #1 of 11 (permalink) Old 04-20-2018, 08:31 AM Thread Starter
Helped a friend build an 05. Pretty much same thing as mine, but with a Wiseco piston instead of stock. HRC cam, stock carb (40 pilot 170 main) Yoshi exhaust and no airbox lid. Carb is clean as a whistle and gas is a week old.
Valves are shimmed at .006 and .011 and decompression is set to 75 psi while kicking @ wfo throttle. Cam timing is dead on. Idles great. I don't think it would kick over in one kick if it was off.
Tried swapping my ignition module and the coil pack off of my 05. No change. The decompression was set wrong before, was over 110 psi, no change after dropping it to 75. There is a brand new NGK plug in it. New flywheel key too as the old one was worn.
It's almost as if it won't run up to the end of the RPM's. No matter what throttle position, full, mid, whatever, it hits a certain point and it starts backfiring and shooting flames.
I think the stator in his bike is aftermarket. And I know how suspect they can be. This is where I keep coming back to as the problem. Am I on the right track?
Thank you
- Phil
'05 TRX450R - '05 CBR600RR
phillybuilt is offline
post #2 of 11 (permalink) Old 04-20-2018, 09:54 AM Thread Starter
Typo: 50 pilot not 40...
- Phil
post #3 of 11 (permalink) Old 04-20-2018, 11:10 AM
Go to a bigger main.
04 450r
duke416ex is offline
post #4 of 11 (permalink) Old 04-20-2018, 08:46 PM Thread Starter
Thank you for the reply, Duke. We tried 175, 180, and 190, no change. I don't think the main is the suspect though, as the problem happens even with mid throttle, like way before you open the main jet. It's like it hits a wall.
The bike also has a new Honda wiring harness too, all grounds are clean. The stator looks like one of the ones you get off eBay for 50 bucks. The wiring by the big plug looks suspect too. It feels like one of the connections has been repaired under the tape. I know from my banshee days that anything besides an OEM stator can be a problem.
After building an engine from the cases up, powdercoating the frame, new plastics, the stator is a drop in the bucket. Going to try that because it's suspect, and even if it isn't the problem, it's a known unreliable part. This is one of the few things he kept from the original engine that let go (bad crankshaft bearing ate cases up)
- Phil
post #5 of 11 (permalink) Old 04-20-2018, 10:50 PM
mailman's Avatar
Stator is bad. Replace the stator with a known good one. I have seen this issue on 2 differenct 05's.
Just a little more HP and I should be set.
mailman is offline
post #6 of 11 (permalink) Old 04-21-2018, 07:18 AM Thread Starter
Thanks for the reply, mailman. Ironically I found one of your threads from years ago, where you replaced the stator and the intake valve springs. We have been through the same testing you have in that thread, including pulling the head back off and double checking all of the valves for leaks with carb cleaner.
Stator and gaskets are on the way, will post back next week when they arrive
- Phil
post #7 of 11 (permalink) Old 04-23-2018, 08:56 AM
I had the exact same symptoms on my 05 that you're having.
My bike had been sitting up for about 6yrs.
When I finally decided I needed to either ride it or sell it, I rebuilt the top end with new oem piston, rings, intake valves, and cam chain. I also cleaned out the carb, the tank, and put in fresh gas, and cranked her up. It cranked and idled fine. But when I rode it, the bike would reach about half throttle and start acting like it was hitting the rev limiter. So I tried the same things you have tried to fix yours, including replacing the stator. It still did the same thing. I'd warm it up and ride it, and at half throttle it would be like a fireworks show.
Mine ended up being weak intake valve springs causing the problem. I should have checked them when i replaced the intake valves, but I didn't. They were the original springs that had been in there for 13yrs...
After replacing the springs (intake and exhaust) the bike ran great!
I would try that, IF the new stator doesn't fix your problem.
Keep us posted on it.
JBplays01 is offline
post #8 of 11 (permalink) Old 04-23-2018, 09:46 AM Thread Starter
JB thank you for the reply. This was a built cylinder head with aftermarket valves and dual valve springs with different retainers. We got it from an 04 I parted out with a bad crankshaft bearing. Compared to the stock springs, these feel pretty taught. I had the head apart to lap the valves back in before we put it together. Although I won't rule anything out at this point...
The new stator should be in this week. Looking forward to seeing the results.
Being that these are aftermarket dual valve springs, I would think one of them would actually break or collapse before they just became weak and no longer held good spring pressure. Then again, I've seen stranger things.
- Phil
post #9 of 11 (permalink) Old 04-23-2018, 03:21 PM
Be careful lapping those valves in, certain valves have a coating on them and if you lap through that coating the valves won't last very long. That's been my experience at least.
04 450r
post #10 of 11 (permalink) Old 04-23-2018, 03:46 PM Thread Starter
I did not know that. Before we put the engine together, the intake sides were both leaking carb cleaner through the valve seats. The valves cleaned up with very little lapping, I guess we'll see in a matter of time if they last or not.
- Phil
post #11 of 11 (permalink) Old 04-26-2018, 05:25 PM Thread Starter
Update: new stator came in, put it in this afternoon, all better now. No more false limiter, no hiccuping, idles nicer too. Bike is 100% again. Thanks for everyone's input.
hoser likes this.
- Phil
