Strange Electrical Problem - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 6 (permalink) Old 10-27-2017, 11:31 AM Thread Starter
I'm building an 05 for a friend of mine. Powdercoated frame, total engine build, etc. Lots of new parts.
At first it had no spark, I found that the wire going into the spark plug boot had corroded, so I cut back 1/4" and threaded the boot on. That problem is solved. Quad starts right up.
Randomly, I get shocked through the handlebars. Not badly, but enough that I notice and shut it down. Very strange issue.
It has a brand new OEM engine harness, new OEM kill switch, engine is redone with new cases, frame was powdercoated. I sanded down the tabs where the coil mounts to for a good ground.
It still happens if the kill switch is disconnected from the bike (first thing I tried) going to try disconnecting the key but I think I did and it made no difference.
Should I be sanding down any other spots? Like where the engine is bolted to the frame? Any other ground spots I'm missing?
Thanks guys
- Phil
'05 TRX450R - '05 CBR600RR
phillybuilt is offline
post #2 of 6 (permalink) Old 10-27-2017, 05:10 PM
Sheerider11's Avatar
Thanks guys
Yeah.
Grounds wires never hurt either. I like lawn mower starting cables.
I'd be checking that tho. Imagine if you get wet and muddy. That shock will probably feel like a kick in the nuts for sure. I've seen a lot of people wire up tethers wrong or old ones shock
Sent from my SAMSUNG-SM-G891A using Tapatalk
Sheerider11 is offline
post #3 of 6 (permalink) Old 10-27-2017, 05:23 PM Thread Starter
Originally Posted by Sheerider11 View Post
Yeah.
Jeez Rob you're everywhere haha
04/05's are kinda funny, besides the one that bolts to the top of the coil, there are no ground wires on this thing that bolt onto the frame. I think I'm going to shave inside all the engine mount spots and spacers for good measure.
I ended up finding the issue when I went back to try without the key, found two wires on the key switch harness were melted on the inside. Soft enough to where they weren't always stuck together but if you hit a bump the right way it would make contact. Easy fix.
- Phil
post #4 of 6 (permalink) Old 10-27-2017, 05:25 PM
Yeah I get around. This is my buddies that I've been learning on.
post #5 of 6 (permalink) Old 10-27-2017, 10:02 PM Thread Starter
Seriously dude, what don't you own or have access to? Lol
How do you like it compared to the YFZ? And what's done to it?
- Phil
post #6 of 6 (permalink) Old 10-31-2017, 09:18 AM
Lol I surround myself with options.
It's a cool bike for sure.
It doesn't compare to the yfz at all tho. His bike just has a full exhaust and uni filter.
So it's apple and oranges.
But for just that, it sure does pull really good. I can see throwing on a cam and a fci it'll probably really wake it up.
