oil lines from a 05 question and concerns - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 1 (permalink) Old 04-11-2011, 02:54 PM Thread Starter
Cooptrx51's Avatar
hey guys im wonderinf if you can cut the stock oil lines and put a fitting on the end of it like a threaded one. the reason i ask is that i need to connect my stock oil lines to a pwr radiator with a built in oil cooler, and the fittings need to be threaed to work. so let me know what your guys opinions are?
05 Trx450r
Rossier Epoxy port
Rossier full system exhaust
Rossier full intake
493/739 cam
+1 ti valves
KW hd springs
13.5:1 JE piston
hot rods crank
asv levers
hipers
laker custom
quadcross tires
flexx bars
PWR radiator
elka suspension
walsh arms
jb superlink
RPM axle w/anitfade
quadtech seat
houser nerfs
"lifes short live it too the fullest"
Cooptrx51 is offline
