EFI Conversion on 05... thoughts, ideas, concerns, other... - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 10 (permalink) Old 01-16-2011, 09:45 PM Thread Starter
Bravo_Three's Avatar
Ok so I was on ebay looking up FCR carbs and I have come across several people selling complete EFI kits from off the 09+ dirtbikes... I mean wiring, ecm, flywheel, sensors, throttle... like i said, pretty much everything but fuel pump. Now heres what I was thinking, would it be possible to retro fit the dirtbike EFI system onto an older 05 engine... I live at 5200 ft and ride up into 7000+... EFI could be very nice... So I was just wanting to know if anyone has attempted this or if anyone has any insight onto the matter... thanks yall...
So it is true... I am awesome.
05 - 450R - used in March of 2010
Stock as all get out
07 - 400ex -Brand new in 06
Engine-
Stock
Protaper bars - ATV mid bend on Trail Tech Risers
Bravo_Three is offline
post #2 of 10 (permalink) Old 01-16-2011, 11:14 PM
Mbirt's Avatar
The CRF flywheel is a smaller diameter than the TRX's. The flywheel's 12 teeth will be too far away for your VR sensor to see. And the CRF uses 2 VR sensors to read those 12 teeth. Your left crankcase cover has no mounting for the second VR sensor. Furthermore, the '09 CRF flywheel may not be compatible with the taper of the snout of your crank. I'd like confirmation on this last bit. It'd help me out greatly (desiring to use 2009 450R flywheel on 2006 CRF450X with megasquirt).
I'd say your best bet is to pick up a Microsquirt, machine the long/short teeth from your flywheel, press on the trigger wheel of your choice, and pick up cheap LT-R450 components for everything else (especially that nice external fuel pump).
96-2010 DR650SE Fuel Injection Project.... - ThumperTalk
The attached picture is our EFI 450X here at Kettering for our Formula SAE car. I can testify that you will become an expert in automotive wiring in no time.
Lead Technical Engineer, Kettering University Formula SAE
http://orgs.kettering.edu/fsae/
Mbirt is offline
post #3 of 10 (permalink) Old 01-21-2011, 02:51 AM Thread Starter
Thank you for your input, I am still learning a lot about all the variations of the Honda 450 engine. And I already do a lot of wiring with deutsch connectors on heavy equipment... Im a mechanic at a coal mine in Wyoming.. But like I said I am still learning about these engines, thanks for your help.
Engine-
Stock
post #4 of 10 (permalink) Old 01-21-2011, 08:10 AM
mcoughlin's Avatar
What's the VR sensor that you are talking about?
Black 05 R...........Red 05 R
SOLD..................Winter Build
Black & Blue.........Black & Yellow
mcoughlin is offline
post #5 of 10 (permalink) Old 01-21-2011, 10:18 AM
450R XC Rider
450rquadrider's Avatar
Location: Ashland, Virginia(Currently in Blacksburg, VA Go HOKIES!!)
Just wondering, is the kit you are looking at a closed loop or open loop system? from what I read, most dirt bike and atv engines are open loop due to the preprogrammed maps.
07 450er- HMF, Powermadd, ASV, ITP, Holz, Uni, Pro Armor, Pro Taper, Streamline, Tusk, Teixeira Tech, Laker Customs, Oury, GT Thunder
450rquadrider is offline
post #6 of 10 (permalink) Old 01-21-2011, 03:47 PM Thread Starter
It was an open loop system straight off an 09 CRF450r...
Engine-
Stock
post #7 of 10 (permalink) Old 01-21-2011, 05:49 PM
trx500r's Avatar
I have a mega squirt/mega tune system for the trx450r retail was $1500 ill take $550 shipped. Its a full stand alone system. Very nice setup just need dyno to dial it in
Just a Slow Honda
trx500r is offline
post #8 of 10 (permalink) Old 01-22-2011, 01:12 PM
Mbirt's Avatar
PM'ed
Mbirt is offline
post #9 of 10 (permalink) Old 01-22-2011, 01:22 PM
Mbirt's Avatar
The TRX450ER FSM refers to it as the "Ignition Pulse Generator". You can use it with aftermarket EFI to detect a more standard trigger pattern to precisely control spark. It's in the box in the attached picture.
Mbirt is offline
post #10 of 10 (permalink) Old 05-15-2012, 10:09 PM
Luc
Here can I buy this kit new in box.
Thanks.
Luc is offline
