Help- throttle conversion - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 2 (permalink) Old 04-15-2019, 01:20 AM Thread Starter
I’m wanting to switch my twist throttle to a thumb throttle as I do mostly trail riding. Do I need to get a different cable or will the one I have work with the new thumb throttle? I ride a 06 450
Caitlyndrago is offline
post #2 of 2 (permalink) Old 04-15-2019, 07:11 AM
CJM
CJM's Avatar
All you should need is likely the cable and a thumb throttle off a 400ex or 04-05 450r. The throttle safety is already bypassed most likely (keeps the throttle from running away). Bonus you can use a TRX90 throttle lever (its longer) more leverage than the others.
-2006 450R. New WHIP..
CJM is offline
Similar Threads
kicker conversion kit, 04/05 carb and throttle, and more to come OhaRe Parts/Accessories 0 12-05-2011 09:19 PM
2006 TRX450R Streamline twist throttle conversion kit duneracer450 Parts/Accessories 0 11-19-2008 12:32 AM
wires coming from thumb throttle keeping me from installing twist throttle mccown450 Body, Controls, and Protection 2 09-02-2007 12:37 PM
Thumb throttle conversion chris46 Lounge 15 11-13-2005 09:02 PM
throttle cable & thumb throttle jabbahoo Body, Controls, and Protection 3 02-17-2005 08:59 PM
