What jet size? - Honda TRX Forums: Honda TRX 450R Forum
 1Likes
  • 1 Post By Tac
post #1 of 11 (permalink) Old 06-15-2019, 12:42 PM Thread Starter
Tac
Tac's Avatar
What jet size?
Just got my 2014 trx450r back from the shop,it has 10hrs on the quad I installed a full monster exhaust, stage 2 hot cam,k&n filter & stage 2 jet kit the shop put the biggest main jet in a 140 & it runs like crap it sputters 1/2 the time around 1/4 to 1/2 throttle then clears up. Is the main jet way to small? Also when I put a k& n filter lid it runs worse what's up? Please help
Tac is offline
post #2 of 11 (permalink) Old 06-15-2019, 04:24 PM
CJM
CJM's Avatar
162, remove airbox lid
-2006 450R. New WHIP..
CJM is offline
post #3 of 11 (permalink) Old 06-15-2019, 07:41 PM
Making HP ainít free. . .
hoser's Avatar
If you paid this shop to do these upgrades and make sure it runs properly, take it back to them and hold them liable.
hoser is offline
post #4 of 11 (permalink) Old 06-19-2019, 07:28 AM
Ryan94Wright's Avatar
First thing I would suggest as CJM said Remove the air box lid, they do not run for **** with the lid on with an aftermarket exhaust.
I think the reason Tac is on here asking is because he might be thinking the same thing as me.... If a shop didn't get test the bike to make sure to run right the first time working on it so it doesn't have to come back ... then clearly I wouldn't take it back to them because they probably wont have it right the 2nd time for all we know. Not to mention a lot of small business's buy kits like Dyno Jet and other off brand Jets that are measured different then OEM because they're way cheaper and you can get them in "kits". Sometimes you throw in jets and you get lucky and the bikes run fine.
What brand jets did they use? Do you know?
If it's a Dyno Jet brand or any other off brand jets that means their numbers are totally different then Keihin Jets or (oem Jets).
A lot of people get confused with this and causes a **** ton of tuning issues and head ache. Someone says "Use a 150 or a 160" for example but
what the person telling you that info doesn't know is that they're using DynoJet and the person doing the install is thinking "180" but really you
just installed a installed a bigger jet then you thought. That 180 is really equivalent to a 202 OEM jet.
There is absolutely nothing wrong if you used Dyno Jets, just make sure to use the converter chart when doing so. I'll leave a link for the
conversion
https://www.jetsrus.com/FAQs/FAQ_mik...ihin_sizes.htm
Build Break Rebuild Better
Ryan94Wright is offline
post #5 of 11 (permalink) Old 06-20-2019, 07:14 PM Thread Starter
Tac
Tac's Avatar
conversion
Thank you it's a 140 dyna jet
thanks for the info it's a dyna jet
Ryan94Wright likes this.
Tac is offline
post #6 of 11 (permalink) Old 06-20-2019, 07:59 PM
You need a 180 main jet or bigger..
This is same set up as yours pretty much.
Fleeela is offline
post #7 of 11 (permalink) Old 06-21-2019, 05:24 PM Thread Starter
Tac
Tac's Avatar
180 dyna jet or keihen
Tac is offline
post #8 of 11 (permalink) Old 06-21-2019, 05:25 PM Thread Starter
Tac
Tac's Avatar
Ps thanks so much for the help u r awesome
Tac is offline
post #9 of 11 (permalink) Old 06-21-2019, 10:23 PM
keihen. Start at 180 and keep bumping up if you need to. I'm running a 200main, but I also have fci intake.
Fleeela is offline
post #10 of 11 (permalink) Old 06-28-2019, 01:58 PM Thread Starter
Tac
Tac's Avatar
Update got it back from my old shop only took 1 hr installed 150 dyna jet main jet & installed k&n filter lid runs great now! Thanks so much to everyone for the help you guys are great!
Tac is offline
post #11 of 11 (permalink) Old 06-28-2019, 06:58 PM
CJM
CJM's Avatar
Sign..dyno crap..
See they work but they are never as good a tolerance as hex keihin still jets. Im glad you got it sorted out at least.
CJM is offline
