Hiper rims - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 3 (permalink) Old 06-10-2019, 08:43 PM Thread Starter
Hiper rims
I just picked up used hiper rims, I put the on and they are rubbing the tie rod end. What's causing this? The rim offset?
Mckinley442 is offline
post #2 of 3 (permalink) Old 06-11-2019, 08:22 AM
Making HP ainít free. . .
hoser's Avatar
Even with 4+1 offset they shouldn’t be rubbing. Do you have different arms or hubs on your quad?
hoser is offline
post #3 of 3 (permalink) Old 06-13-2019, 08:40 AM
fmxguru's Avatar
Need a little more info. Arms, front end components (spindle,hub,caliper). I run single bead lock CF1's in the front and have never had an issue (I run lonestar arms and spindles with oem hubs, calipers, and tie rod ends. Can you take pictures of the situation?
2004 trx450r
fmxguru is offline
