Trx450r - Honda TRX Forums: Honda TRX 450R Forum
 3Likes
  • 1 Post By hoser
  • 2 Post By Sheerider11
post #1 of 6 (permalink) Old 10-12-2016, 10:32 AM Thread Starter
Trx450r
I have a leak coming out of rear of my trx450r looks like engine oil or brake fluid but I haven't dug into it. Any ideas what this can be
Sent from my SM-J320V using Tapatalk
laynekyle95 is offline
post #2 of 6 (permalink) Old 10-12-2016, 12:16 PM
Making HP ainít free. . .
hoser's Avatar
Cracked engine case
Blown gasket
Blown shock
Cracked brake line
Loose brake banjo bolt
Clogged engine breather hose
Bad spark plug tube gasket
Leaking caliper
Cut shifter shaft seal
Bad oil drain sealing washer
Pinched head cover gasket
Cracked head
Scratched caliper piston
Loose master cylinder cover
Engine too full of oil
Loose oil filler cap
Possibly 20 or 30 other things, but that's all I can think of with such a vague question. . . . .
hawk-trx likes this.
hoser is offline
post #3 of 6 (permalink) Old 10-12-2016, 12:27 PM Thread Starter
Originally Posted by hoser View Post
Cracked engine case
Blown gasket
Blown shock
Cracked brake line
Leaking caliper
Cracked head
It's small leak understand rear skid plate underneath rear break
post #4 of 6 (permalink) Old 10-12-2016, 01:00 PM
Sheerider11's Avatar
Dude come on.
If you cant figure out simple stuff like this, what's going to happen when.you have a real issue.
Figure out what it is and where it's coming from at least.
Not
"I have a leak, what is it?"
Sent from my SAMSUNG-SM-G890A using Tapatalk
hawk-trx and hoser like this.
Sheerider11 is offline
post #5 of 6 (permalink) Old 10-12-2016, 01:36 PM
Gustav's Avatar
Take a shooter of oil/remember the taste,take a shooter of brake fluid/remember the taste,clean your mouth out with scope & taste this leaking fluid & work your way backwards.just kidding e-bodies have fun with you for breakfast,wild guess would be engine/trans oil since brakes don't usually leak brake fluid unless you crashed.hit it with the pressure washer warm it up & dry it off it will be easier to find,keep us posted,thx
Gustav is offline
post #6 of 6 (permalink) Old 11-08-2016, 07:18 PM Thread Starter
K
