**Cali450R**
Nov 18 2009, 05:31 PM
i just put a 40 T sprocket on my trx450R to get off the line faster good idea or bad
nuckinfuts
Nov 18 2009, 05:34 PM
That's going to depend on what type of soil you're riding on. In some cases it will help but then hurt your top end. Was your bike bogging off the line before? If not, it might not make much difference.
**Cali450R**
Nov 18 2009, 07:45 PM
QUOTE(nuckinfuts @ Nov 18 2009, 05:34 PM)
im just asking for some help that all and trying to put that on soon that why
nuckinfuts
Nov 18 2009, 08:44 PM
Maybe I was thinking too critically here. Dropping one tooth in the front is a lot of difference. This is about equal to two in the rear. Going up one maybe what you're looking for. I tried a one tooth smaller counter sprocket up front and it was too much so I went back to stock on both my 400ex and 450r. When you get into tight trails on the 450, it can seem to have a tall first gear. Try what you have and see how you like it. Hope this helps
Jonhyboi
Nov 18 2009, 09:30 PM
it depends on what your doing to.
but if your looking for more take off power. have at it
**Cali450R**
Nov 18 2009, 10:28 PM
QUOTE(nuckinfuts @ Nov 18 2009, 08:44 PM)
yeah i think that what am going to do stay stock on front and 40 t on rear see what that dous to the bike
2005trx450r05
Jan 1 2010, 03:44 PM
QUOTE(**Cali450R** @ Nov 18 2009, 05:31 PM)
okay if you go UP on a tooth in the front you got more top end if u go DOWN u got more acceleration
if you go UP in the back u got more acceleration if you go DOWN in the back you got more top end...am i wrong guys
Mean05R
Jan 1 2010, 03:59 PM
What kind of riding do you do?
duner450r
Jan 6 2010, 09:21 PM
"okay if you go UP on a tooth in the front you got more top end if u go DOWN u got more acceleration
if you go UP in the back u got more acceleration if you go DOWN in the back you got more top end...am i wrong guys"
thas is correct.....mostly. if you gear for lots of top end, your engine may not be able to pull the hi-speed gearing, and actually slow you down
poorboy
Jan 6 2010, 10:31 PM
QUOTE(nuckinfuts @ Nov 18 2009, 07:44 PM)
on the 06 up going down one tooth is alot more extreme than the 04-05. 05 gearing is 14 38 while 06 plus is 13 38. the 05 has wsome long gears down low. on stock to mild machines it really helps in woods and launh to go down a tooth up front. Of coarse when you step up the wilder motors you find yours self having to short of gearing stock and going 15 and 16 fronts. It's good feeling to be 15 38 and still having a useless 1st and 2 nd gear.
2005trx450r05
Jan 9 2010, 05:40 PM
[what do you mean?
