QUOTE(wannabe_MXer @ Dec 2 2009, 09:51 AM)
Well got the oil, filter, and tranny fluid changed without issue (so far). I just used Honda conventional oil, Honda filter, and Honda tranny fluid. Took it out for a nice easy test ride afterwards and it ran and shifted fine. Only thing I'm not sure about is the oil level. The how-to said to fill to the "H" line on the oil window so I did that. But after I started it, let it run, and shut it down the oil level didn't quite get back up to the "H" line even after it sat for a while. I assume this is because some of the oil is held in the filter, but am I supposed to add a little more oil to bring the level back up in the window? Thanks.
When you say Honda conventional oil, what oil exactly are you using? The 450r demands only specific oils for its high performance engine, so you might not be running the best possible oil you can, hurting performance and protection.
As for the oil level that is correct, some might need to be added.
Start the quad, let it warm up then shut if off, and let it sit for about 3-5 min. then see where the oil level is and add as much as is needed.
