Full Version: kickstarter is leaking oil
bambam
im new to all this , its 04 450r and its leaks oil from the kickstarter how do i fix it? thanks
Scro
Make sure there isn't a hair line crack in the case behind the kickstarter. If there isn't, you just need to replace the seal. Remove the allen head bolt, and the kicker assembly will slide off. You should be able to pick the new out, and install the new. Pretty easy job.
bambam
QUOTE(Scro @ Nov 18 2009, 01:54 PM) *
