Full Version: LONG Travel versus STD travel defined
Nick @ JET Suspension
This question has been asked so many times that I feel a need to explain - which of course opens the flood gates. If this is too lengthy, I apologize, not easy to explain quickly.
There are two different issues that can be affected
First Long Travel and increased wheel travel can be two different things.
Increase wheel travel (Extra Travel, extended travel) is any modification that increase the wheel travel over stock travel. For example the stock 05 TRX450R wheel travel is roughly 9 5/8". This is the amount of wheel movement of both compression and extension which are dictated by the max extended length of the shock and minimum compressed length of the shock (including the bottom out bumper fully compressed). If we remove the shock, then measure wheel travel then the limiting factor of wheel travel become the BIND points of the upper and lower ball joint, mechanical interference with tie-rods, etc. or bind of the tie-rod end itself, this is all obviously BAD NEWS. Given this, we want the SHOCK to control the maximum travel so we don't have a ball joint failure etc.. This would be a pretty crappy day especially rolling through the woods in any gear as the trees never seem to move out of my way, go figure. I'm sure the surgeons don't mind, but I sure do.
LONG TRAVEL is increasing SHOCK travel which will allow or not allow any increase of wheel travel. This is accomplished by the A-ARM manufacture moving the lower shock mount from its stock location and relocating it out towards the spindle, which will require a longer shock. This does give the ability to increase wheel travel, but we can still be limited by the BIND POINTS of the ball joints. This is why the angle of ball joint mounting on the a-arm or type of ball joint is so important. This is also why each a-arm manufacture has their OWN specs on shock length. Again the SHOCK should be the limiting factor of compression and extension length. I can elaborate alittle more on this with a future post if you have specific questions. This is where we get into motion ratio - which is the amount of wheel travel compared to the amount of shock travel. If wheel travel is 10" and shock travel is 5", this would give us a motion ratio of 2 : 1. This also points out the mechanical advantage or leverage ratio. So the long story short, can std travel do the same as long travel and the answer is YES. the mechanical ratio can be duplicated from a long travel to std travel and vice versa. A longer shock travel does move more oil and gives more control of the shock tuner. The cross over position is easier to obtain but still can be done with std travel. Long travel will typically lead to aftermarket shocks and there lies another advantage on a few fronts. However, when someone is asking is long travel better, the answer is it can be if wheel travel is gained, can also be NO if there is no wheel travel gain. Keep in mind, that many aftermarket shocks have their inherent advantages in part design, adjustment range, piston oil flow etc..
Do the a-arms change the ride height? Two items affect this, which is width and lower shock location. If the springs on the shock are not changed and simply change the a-arm width, then YES it will put more torque on the spring stack and will sag more lowering the ride height. However, this is not the way to develop spring rate!
Should I get Long travel or Std travel? I can't answer this for you, only give you the information to make your own informed decision. Biggest factor is obviously cost. As stated above the are advantages to long travel versus std travel.
Can std travel feel the same as long travel if wheel travel is the same? Yes, you can duplicate the SAME spring rates on a standard travel as a long travel, but the crossover position must be more precise.
Lets move on to LT REAR suspension.
If the same question is asked for the rear if LT is an advantage, then that is another discussion. I have no issue with increasing rear wheel travel but there are three things that i look for in a linkage and shock combination; amount of progression, ride height and down travel. Increasing the up travel or rear shock fully extended can be a detriment. There are way more ill affects on have a long extension length. This can be very unnerving on a down hill especially try touching the front brakes...enjoy or you feel like your falling over the front on corner entry. Long travel rear requires an aftermarket shock and will typically be a dual rate. Long travel links have less progression and allows the shock builder to build the spring rates to become the progression of the rear suspension versus a mechanical and therefore FIXED progression. If the progression is controlled by the spring stack, then we can adjust and fine tune the progression, the crossover position and spring stack instead of being mechanically stuck to the progression of the link. This decision can also come down to cost. I don't want to make a stand on a particular link versus the other here, but obviously based on the items I look for in a link, this leads me to work with some specific links and not others. There are numerous links on the market and truthfully I haven't tested all links, so just because I don't offer them doesn't mean I like or dislike them.
Will post more if you like and if I can get the time, but by all means I am not implying that I know everything and I make it appoint to always learn, test, try new tricks, and basically try and screw with every portion of suspension to see if we can find an advantage, which means i'm not afraid to answer I DON'T KNOW, but lets see if we can figure it out!
Nick @ JET
duke416ex
Talking about shock mounting point. I have read a lot on this but so much information seems to go against other stuff. How much does the shock angle affect things?
Also what about heat issues due to the long shock having more fluid? I always had trouble with revalved front fading very badly and seemed that due to heating more they needed servicing more regularly. Just what I had trouble with though. I would like to talk to you about some rear stuff, but might be better at the track.
QUOTE(duke416ex @ Nov 5 2009, 10:25 AM) *
Shock angle @ roughly 10% will decrease the rate approx 5% and the greater angle will soften the spring rate to as much as 25%.
duke416ex
Different subject kinda, but what about caster. I read some places + caster is the upp ball joint in front of the lower and in other places they say the opposite. Which way is it. I have been told yfz's do better with the upper to the rear, but I like my Honda more to the front, any recommendations?
QUOTE(duke416ex @ Nov 30 2009, 10:27 AM) *
Positive Castor is the upper ball joint leaning back toward the rear tire, which promotes the steering to stay straight (like a bicycle), negative is the upper ball joint further forward of the lower ball joint which promotes turning (like a shopping cart) - very dangerous! Castor ranges on an atv from 3 to 7 degrees (less if you are on a turny track, more if your on a high speed - like desert racing). I like to start high, then roll it forward until it starts to wonder on straights, then back .5 degree, unless turny track, that I go opposite, start low and increase until turning gets difficult, then back forward .5 degree. Your arms will feel it if it is off!
duke416ex
Huh, well I have SMC caster adjustable uppers and am running all the shims in the rear. Maybe I need to do a little more testing, but it felt good for the 2 miles I got to do of the last race! Are you doing any classes this winter?
QUOTE(duke416ex @ Dec 1 2009, 09:38 AM) *
We will be doing suspension test and tune sessions again starting up in mid Feb., I will posting the schedule soon on the website on the front page. www.jetsuspension.com
duke416ex
What about rear linkages and more travel? I have 5 or 6 different linkages and just trying to figure out which way to go. I have an 06 dual link and was thinking of having a shock built for it. Do you have much luck on these linkages? I also have a couple different gt linkages and a couple other Elka links. What linkages do you think work best?
QUOTE(duke416ex @ Dec 1 2009, 11:57 PM) *
Will you be at the Mid-south this weekend in Vanleer TN? If so, we will be setup there - can't miss us, look for the JET aerial flags, and bring the links with you and we can figure out which one to go with.
Nick
duke416ex
lol, I should be there, I guess I do have a lot of questions! Hopefully I will get there in time to come find you.
QUOTE(duke416ex @ Dec 2 2009, 10:11 AM) *
I will be there and setup Saturday early evening and be there through the ATV race
