Full Version: ITP wheels
2006R
Well i will be buying some itp wheels in a month or so and have 1 question everyone says that the black T-9 ITP wheels the black will chip off..... Anyone else had an experience like this before..... Also I stumblled across a post about not using your stock lugnuts on aftermarket wheels do to making the wheels get stuck on there... . I was not aware of this so what type of lugnuts should i get
450R Duner
QUOTE(2006R @ Oct 29 2009, 10:38 AM) *
I had mine chip after one ride in the sand but had no idea this was a common problem. If so I don't think I will but ehm again anyone else have any input on this and if so what are so good alternatives for black rims?
duner450r
"...good alternatives for black rims? "
hipers...guaranteed not to knock the black off them!!
as for using stock lug nuts on after market wheels.....just flip them around so the flat part is against the wheel. even better is to use washers. this will keep the nut from digging into the wheel.
some aftermarket wheels need the taper, most do not. look at the stud hole in the wheel. does it have a matching taper for the nut to seat against? if not...DO NOT put the nut's tapered end against the wheel!!
450rcullen
My ITP black bead locks have some chips i noticed the other day. I have bajas up front and not sure if they chipped or not ill have to get back to you on that one. Does anyone know where i can find some mudplugs for the beadlocks??
